Different approaches can work as long as you maintain continuity in the ground. More
Q. My client's metal fireplace is supplied by a makeup air system with a built-in... More
Q: I know that knob-and-tube wiring can't be covered with insulation, but what about BX cable and joist-mounted junction boxes? Are there any restrictions on blowing cellulose insulation into an attic and burying the cable and junction boxes? More
A master electrician describes how to trace wires, identify circuits, and diagnose common job-site electrical problems. More
Wiring for the future comes to the present More
Q: I have always thought that the best way to wire a receptacle is to use a... More
Q: What is the maximum number of 12-gauge wires permitted in 3/4-inch conduit? More
Q: What is an arc-fault circuit interrupter? Are they expensive? Are they subject to nuisance tripping? More
Q: Can you keep old armored-cable circuits, or should you replace them? If you... More
