Main Service Instruction
Grounding Electrical Boxes
Different approaches can work as long as you maintain continuity in the ground. More
Pigtails for Switches?
Is there any advantage to wiring switches with pigtails? More
Wind- and Solar-Powered Generator
Batteries that are recharged by solar panels and a wind generator supply DC power... More
Q&A: Service-Entrance Cable Under a Garage
Q: The proposed location for my client's new detached garage is right on top of a buried service-entrance cable. The electric meter is mounted on a pedestal about 100 feet from the house, and a conduit runs to the house through the area where the garage — More
Moving an Electrical Box
What's the solution when the location of an electrical outlet needs to be adjusted... More
Using A Volt-Ohm Meter
A master electrician describes how to trace wires, identify circuits, and diagnose common job-site electrical problems. More
Q&A: Circuit Breaker Problems
Q: In a residential remodel, we replaced the electrical service panel. Within five days, two of the 15-amp breakers tripped and could not be reset. The breakers were determined to be "defective" and had to be replaced. What could be causing this problem? More
Q&A: Arc-Fault Circuit Interrupters
Q: What is an arc-fault circuit interrupter? Are they expensive? Are they subject to nuisance tripping? More
Q&A: Tying into Old Armored Cable
Q: Can you keep old armored-cable circuits, or should you replace them? If you... More
Q&A: Upgrading Two-Prong Outlets
Q: How about upgrading old two-prong ungrounded outlets from the ’70s and back? More
