This cladding absorbs and hold water, so it's not surprising that installation... More
What's the best way to create a non-combustible surface behind a gas stove in a living room? More
Make sure you get the water-management details right the first time around. More
Installing one of these membranes can help prevent rot behind stone and masonry... More
Wedge-type or masonry anchors can crack granite. Fortunately, there's a safer and... More
If the wall behind the veneer is detailed properly, critters shouldn't be able to... More
Q: Last spring I completed a house with manufactured stone columns on the porches... More
Q: I have been told that the oils in a penetrating oil-base stain will improve old, dry clapboards. Is this true, or would it be better to seal the weather checks with a high-quality oil-based or latex paint? More
