Back to Basics: Wood Clapboard Siding
Jeremy Kassel walks us through the steps of an impeccable siding install. More
Moisture Protection for Walls
Doug Horgan dives into a range of practical solutions for draining and drying... More
Working With Poly-Ash Siding and Trim
Mike Sloggatt weighs in on the pros and cons of TruExterior poly-ash exterior... More
Installing Effective Rainscreens
Simple, low-tech systems that can work for any type of siding More
Getting Kickout Flashings Right
Leaks are a liability. It's so much easier and less expensive to invest in $15... More
Rainscreen Clapboard Siding Details
How to apply strapping and vent screens to create a drainable, ventilated... More
A Stress-tested Rainscreen Siding Detail
Are you sure that the screws you're using to fasten vertical strapping over... More
No-Leak EIFS
Improved waterproofing and drainage details promise rot-free performance from this... More
Weather­tight Exteriors
Keeping Moisture Out of Oceanfront Homes More
