Board Siding Instruction
Making Open-Joint Siding Work
Michael Anschel has a practical recipe for an innovative 100+-year exterior... More
CLT Panel Home Clad in Shou Sugi Ban
The Case of the Sobbing Siding
On a callback for a siding leak, a building inspector discovers that his roof... More
Repainting Aluminum Siding
Q: Does faded aluminum siding with a chalklike residue on the surface require any special preparation before repainting? More
Extractive Bleeding on Cedar Siding
How good water management practices and back priming can minimize this problem. More
Q&A: Caulking Siding — or Not?
Q. When installing cedar clapboard, should gaps between the siding and trim be caulked? More
Q&A: Ventilating a Rain Screen
Q: I plan to install clapboard siding using the rain screen method. The siding will be fastened to 3/4-inch vertical battens, nailed over each stud. At the top, I plan to ventilate the rain screen into the soffit area. What is the best detail to ventilate More
Q&A: Fanning Clapboards
Q: I recently did some work in a house where the electrician found aluminum wiring... More
Economical Wood Siding
Knotty grades are a lot less expensive than clear, but they are also less forgiving. More
