Brick Instruction
Repairing a Frost-Damaged Brick Patio Border
John Carroll explains how to prep the surface, choose the right bricks and mortar,... More
Best WRB Behind Brick Veneer?
Why a conventional house wrap is the wrong choice for use as the weather resistive... More
Q&A: Creating a Non-Combustible Wall Behind a Gas Stove
What's the best way to create a non-combustible surface behind a gas stove in a living room? More
Stabilizing a Brick Exterior
Unstable brick is tied to the floor framing with standard hold downs, threaded rod... More
Reusing Salvaged Brick
John Carroll explains why old brick is best used on interior projects, where it... More
Retrofitting a Brick Wall With Insulation
How to meet energy code requirements for insulation while providing drainage... More
Do Brick Veneer Weeps Need Screens?
If the wall behind the veneer is detailed properly, critters shouldn't be able to... More
How to Flash a Chimney to an Exterior Wall
Here's a leakproof detail for the tricky joint between an exterior masonry chimney... More
Q&A: Best Materials for Poolside Deck
Q: What is the best decking material to use around pools? We have used CCA-treated... More
