Engineered Wood Siding Instruction
Repairing and Replacing Sheet Siding
Minor cracks can be caulked and repainted, but sometimes the best solution is to... More
The Case of the Sobbing Siding
On a callback for a siding leak, a building inspector discovers that his roof... More
Green Alternatives to Traditional Building Materials
Q: I live in northern coastal California, in the heart of the redwoods. We're currently remodeling a simple structure (in a highly visible town-square location) into an elaborately detailed storefront, in keeping with the surrounding 1880s architecture. While all the vintage storefronts (and their framing) are constructed of old-growth redwood, we would like to use modern alternatives — such as engineered products — that would be more environmentally responsible. Since the exterior will be painted, the panels, columns, and crown and detail moldings can be built with any product that will withstand our moist climate. Do you have any recommendations? More
Q&A: Ventilating a Rain Screen
Q: I plan to install clapboard siding using the rain screen method. The siding will be fastened to 3/4-inch vertical battens, nailed over each stud. At the top, I plan to ventilate the rain screen into the soffit area. What is the best detail to ventilate More
Q&A: Best Glue for MDF
Q: What glue works best with MDF? More
Economical Wood Siding
Knotty grades are a lot less expensive than clear, but they are also less forgiving. More
