Exterior Caulks and Sealants Instruction
Gluing Exterior Trim
Q: When installing stained vertical cedar siding or fascia trim, what type of glue should be used for splices and corners? Some contractors like to dab a little stain on the cut ends of 3-degree splices or on 4-degree corner miters, but is there an exteri More
Do Fiber-Cement Butt Joints Have to Be Caulked?
Q: The clients on an upcoming project are interested in installing fiber-cement... More
Soundproofing a Through-Wall Air Conditioner
The solution to a neighbor's noisy air conditioner lies at your own bedroom window. More
Q&A: Flashing an Arched Window
Q. What's the best way to flash an arch-topped window? More
Q&A: Caulking Siding — or Not?
Q. When installing cedar clapboard, should gaps between the siding and trim be caulked? More
Q&A: Grout or Caulk?
Q. When installing a mortar-bed shower floor, should the gap between the drain and the adjacent tiles be finished with grout or with caulk? More
Q&A: Sealing Garage Floors
Q: Is a concrete sealer effective at protecting a garage floor from road salt damage? If so, what is the best product to use — a floor paint or a clear waterproofing sealer? More
