Fiber-Cement Siding Instruction
Working With Fiber-Cement Shingle Panels
Cladding a three-story house with fiber-cement shingle panels when there are... More
The Case of the Sobbing Siding
On a callback for a siding leak, a building inspector discovers that his roof... More
Do Fiber-Cement Butt Joints Have to Be Caulked?
Q: The clients on an upcoming project are interested in installing fiber-cement... More
Q&A: Caulking Siding — or Not?
Q. When installing cedar clapboard, should gaps between the siding and trim be caulked? More
Q&A: Ventilating a Rain Screen
Q: I plan to install clapboard siding using the rain screen method. The siding will be fastened to 3/4-inch vertical battens, nailed over each stud. At the top, I plan to ventilate the rain screen into the soffit area. What is the best detail to ventilate More
Economical Wood Siding
Knotty grades are a lot less expensive than clear, but they are also less forgiving. More
