Doug Horgan dives into a range of practical solutions for draining and drying... More
Doug Horgan reports on the three most common EIFS installation errors, and the... More
Replacing a beam is usually straightforward, until you have to also comply with... More
A common stucco failure point is when it wraps from the vertical wall to the... More
Leaks are a liability. It's so much easier and less expensive to invest in $15... More
Assume that 3-coat stucco leaks, and detail the building envelope with careful... More
Late last year, a couple called me about some leaking windows on the back of their... More
