Weather Barriers and Flashing Instruction
Common Flashing Errors
Avoid common mistakes and pay particular attention to these problem areas. More
Sizing Up Window Flashing Tape
Who determines the width of the SAF tape needed to flash window openings - the... More
Best-Practice Apron Flashing
For a more-effective and better-looking result, integrate the exposed apron with... More
Best WRB Behind Brick Veneer?
Why a conventional house wrap is the wrong choice for use as the weather resistive... More
Zip Wall Tips & Advice
Matt Risinger explains how he modified a Zip Wall installation for added durability. More
Installing Windows in a Deep Wall
Double stud walls that allow for higher R-values of insulation create particular... More
Best Practice for Stucco Parapet Caps
To ensure a waterproof installation, use adhesive between layers of waterproofing... More
Stucco Rainscreen – Delta Dry Stucco & Stone Review
How can we build a stucco assembly that will be just as durable and “safe” as a traditional siding house? More
