Placing a Puddle-Proof Driveway
In many cases, using pervious concrete can eliminate the need for expensive... More
Stepped Buttresses for a Row House Basement
As part of a major gut-renovation project on a historic Brooklyn row house,... More
Small Garage Foundation Repair
A mobile concrete mixer solved both budgetary and logistical problems More
Building Stem Wall Foundations - Part II
Continuous steel reinforcement ties the poured concrete walls to the footings More
Building a Stem Wall Foundation
Tim Uhler explains how (and why) his company forms and pours its own foundations... More
Better Concrete Garage Floors
Ten tips for pouring stronger, crack-free concrete slabs. More
Replacing a Slab Foundation
When the original builder flubs a foundation, someone else has to clean up the mess. More
Dressing Up a Gable With a Fiber-Cement Sunburst
Full-scale layout - and a little bit of math - simplifies the process of cutting... More
Adding to an Existing Slab Foundation
An engineered schedule of epoxied rebar pins reinforces the joints. More
Acid Staining a Concrete Floor
With careful preparation, this treatment gives a custom touch to a plain-Jane slab. More
