Jake Lewandowski explains how to repair cracked concrete-block foundation walls... More
A concrete slab improves the performance of an unvented crawlspace, but you still... More
How Jake Lewandowski stabilized an old brick basement wall using vertical I-beams... More
A mobile concrete mixer solved both budgetary and logistical problems More
Hurricane Katrina taught a valuable lesson: the only houses likely to survive the... More
Instead of subcontracting the work, invest in a few masonry tools and put your own... More
A long-lasting set of masonry steps starts with a solid base and includes good... More
In this renovation, engineered steel braces support a solid brick wall from the... More
