Concrete Instruction Articles
How To Repair Structural Concrete
Jake Lewandowski breaks down how to prep a damaged concrete surface and fix it... More
Composite vs. Steel Rebar
Glass-fiber rebar is about one-third the weight of steel rebar, won't corrode, and... More
Control Joints in Concrete Slabs ... Are They Needed?
Cracks in concrete are unavoidable, but contraction and expansion joints can help... More
Best Flashing for Concrete?
Aluminum should be avoided, but what else can you use for flashing with concrete? More
Dropping the Level of a Basement Slab
To avoid cracks, isolate the concrete slab from the footing and foundation so that... More
Pervious-Concrete Benefits
Using pervious concrete on a driveway can reduce runoff and meet many stormwater-management requirements. But does it need maintenance to keep functioning? More
Concrete Cracks – How To Fix
Matt Risinger tackles cosmetic repairs to a polished concrete slab, using an epoxy repair to render unsightly cracks nearly invisible. More
Ancient Roman Concrete Has Lessons for Modern Scientists
Built more than two thousand years ago, the concrete seaport facilities of ancient Rome are still solid. Now scientists are rediscovering the secrets of the Roman engineers’ lost art. More
TJ Shear Brace Installation
A Simpson Strong-Tie rep follows up on a JLC reference to the company's... More
Troweling Air-Entrained Concrete
Can hard-troweling air-entrained concrete lead to delaminations? More
