Blind-Side Waterproofing
How a hillside home's failing block foundation was reinforced by poured concrete... More
Building a Shotcrete Retaining Wall
How to shore up an unstable slope, with minimal formwork and less expense than a... More
Heavy Lift
Raising 250 tons of house safely above the flood was just part of the story. More
Trenchless Excavation
In the hands of a skilled operator, a horizontal boring machine can solve tough... More
Adding Underneath a Hillside Home
A steep slope and a tight lot call for some imaginative foundation solutions. More
Building a Stone Retaining Wall
Fully settled subsoils, a well-compacted base of crushed stone, and good drainage... More
Designing Concrete Basement Walls
An engineer explains how wall thickness, rebar, and proper drainage all affect the ability of poured concrete foundation walls to resist lateral soil pressure. More
Foundation Footing Fundamentals
Concrete expert Brent Anderson explains the code rules and structural issues... More
Practical Foundation Waterproofing
Combined with a working drain, this new type of plastic membrane keeps groundwater out of the foundation while allowing moisture in the concrete to evaporate to the outside. Here’s how it’s installed. More
Foundation Drainage
A concrete contractor and consultant explains how proper finish grading and... More
