Sitework Instruction
Cripple-Wall Failure
Tens of thousands of wood-framed houses in the Bay Area were built on short... More
Repairing a Frost-Damaged Brick Patio Border
John Carroll explains how to prep the surface, choose the right bricks and mortar,... More
Pervious-Concrete Benefits
Using pervious concrete on a driveway can reduce runoff and meet many stormwater-management requirements. But does it need maintenance to keep functioning? More
Helical Pile Foundations
Contractors weigh in on the advantages of helical piles over concrete tubes,in... More
Frost Protection for an Existing Foundation
How a Pennsylvania contractor retrofitted the shallow foundation of a three-season... More
Pervious Paving Offers Coastal Stormwater Solution
Tree Roots and Foundation Cracks
Can the roots of a tree actually dry out the soil beneath a foundation enough to cause the concrete to crack? More
Removing Rocks Without Blasting
When explosives are out of the question, there's a quieter and safer way to break... More
Reinforcing a Slab Over Disturbed Soil
Should rebar be added to a garage slab that spans a utility trench, or should the... More
Building a Frost-Protected Foundation for an Unheated Building
In a cold climate, combining rigid foam insulation with a well-compacted,... More
