A grade beam footing supported by 59 helical piers allows this concrete foundation... More
How a hillside home's failing block foundation was reinforced by poured concrete... More
Neither complicated nor expensive, Jake Bruton's system works extremely well to... More
With the right prep work, a double layer of OSB might be better than a slab More
The house wasn't even done and already the basement had become a wet mess. More
Gaining an extra foot or two of headroom in a basement isn’t easy, but it can... More
We survey the major types of foundation waterproofing, from spray-on to peel-and-stick membranes. More
Building restrictions in California are prompting homeowners who want more space... More
For a high-quality slab, prepping the base and proper layout of control joints are... More
Use this shop-fabricated approach to concrete countertops to improve quality and cut installation time from days to hours. More
