A Study in Broken Load Paths
Jake Lewandowski tackles a remodeling project with numerous structural problems... More
Prepping an Old Bathroom Floor For New Tile
How two Maine builders remediated sagging floor joists in a century-old structure... More
Framing Problems and Solutions
A smorgasbord of specialized structural components was needed to manage this... More
Floor Framing Trouble Spots
Christopher DeBlois explains the critical engineering required to avoid... More
A Flush-Framed Floor to Maximize Space
How replacing a dropped beam and brick pier with steel beams and microlams helped... More
Mudsill Layout for a Complex Foundation
Regardless of style, size, or complexity, all floor framing must start off level... More
Brooklyn Townhouse Makeover: Reinforcing the Floor
Engineered beams, steel joists, and flitch plates help bring a 19th-century... More
Beefing Up a Brooklyn Brownstone's Floors and Roof
A 100-year-old row house’s structural brick walls are more than adequate for the building’s loads. But the floors and roof? Not so much. Here’s a look at how the architect, engineer, and builder teamed up to get modern performance from a historic structure. More
New Joists for an Old Floor
The best remedy for a sagging out-of-level floor is putting in new LVL joists and... More
Drying Wet Framing
In tight houses, make sure the frame is dry before closing up the walls More
