Dimensional Lumber Floors Instruction
Continuous vs. Single-Span Joists
Continuous joists are stiffer than single-span joists that overlap at the center... More
Flush-Framed Floor Joists
Install joists higher than the girder to accommodate shrinkage. More
Setting Mudsills on Out-of-Level Foundations
Grinding down highs is an option, but Tim Uhler says that filling in the low spots... More
Q&A: Long-Span Floor Joists
Q. Would floor trusses or wood I-joists be stronger over a 26-foot span? More
Plumbing Around Floor Trusses
You can move the trap to work around framing, as long as you keep the trap within... More
Q&A: Purpose of T&G Plywood
Q: Does tongue-and-groove plywood add extra strength or stiffness to a floor... More
Q&A: Joist Sizing Rule of Thumb
Q: Is there a simple way to size floor joists? More
Q&A: Painted Plywood Floors
Q: Can painted plywood be used as both the subfloor and finish floor over 24-inch... More
Q&A: Taking the Twist Out of Wide Pine Flooring
Q: We build a lot of reproduction Colonial homes and have problems with wide pine... More
A Builder's Guide to Wood-Destroying Insects
This primer will help you identify the insects that cause damage to houses and specify the right treatment. More
