It's up to the trim guys to adapt to the framing method, not the other way around. More
Can standard galvanized Simpson STHD strap-tie hold-downs be used in contact with... More
Shear walls * Hold-downs * Foundation anchors * Hardware layout * Retrofitting seismic connectors & shear walls * Nailing shear panels * Wood-to-wood and wood-to-masonry roof connections * Roof diaphragm details More
Q: Do you need to put a nail in every joist hanger hole? And do you have to use special hanger nails? More
