Lumber Instruction
Treating Cuts in PT
When the back of a treated 2x10 has been kerfed to create a curved band joist, do... More
Tags: Lumber, Lumber
Precut Stud Lengths
Flush-Framed Floor Joists
Install joists higher than the girder to accommodate shrinkage. More
Fire Protection for Light-Wood Framing
In the wake of the AvalonBay apartment fire in Edgewater, NJ, the wood industry... More
Milling Rough Lumber
For fine woodworking, having control over the flatness and stability of the wood... More
Predicting the Twist in PT Lumber
There's a way to determine which 4x4 or 6x6 PT post is going to twist and which... More
Timber-Frame Look for a Stick-Frame Addition
A few strategically located Doug fir 6x10s help match a conventionally framed... More
Finger-Jointed Studs
Q: Can finger-jointed studs be used for wall plates and short window and door headers? More
Lumber for Permanent Wood Foundations
Q: Is ACQ-treated lumber and plywood suitable for building permanent wood foundations? More
Sawn vs. Plywood Shims
Q: Ideally, pier/beam connections are always properly aligned, with the pier at the right elevation to fully support the beam above. But in the real world, a little shimming always seems to be required. Are shims ripped from framing lumber really adequate More
