Ventilation And Air Quality Instruction
How to Size an HRV or ERV
Unlike a furnace or air conditioner, oversizing one of these can be a good thing. More
Retrofitting Forced-Air HVAC With High-MERV Filtration
Allison Bailes explains why you can’t just swap out a cheap fiberglass filter for... More
Understanding Filter Ratings: MERV, FPR, and MPR
Most discussions about filter efficiency refer to only one rating scale:  Minimum... More
Bring Ventilation Ductwork Inside Conditioned Space
Will Balanced Ventilation Be Required by Code?
Commissioning a Ventilation System
Commissioning is not a word we hear much in residential construction, but it's a... More
Panned Bays
Is it OK to use a joist bay for a return-air plenum in an HVAC system? More
Solving for Comfort With a 'Smart' Thermostat
Tracking temperature, humidity, set point, and equipment runtime can uncover the... More
Installing an ERV in a Two-Family Passive House
JLC’s Coastal Connection goes on site in Boston, Mass., where Placetailor is... More
Diagnosing a Moisture Problem in a New Post and Beam House
If condensation is appearing on windows, green timbers might be contributing to... More
