Retrofit Air-sealing
Phil Armand describes the tools, materials, and methods he uses to air-seal leaky... More
Air-Sealing an Ice-Prone Home
Chris West troubleshoots an ice damming problem in a Cape-style home, a common... More
Air-Sealing Framing
Bad things can happen if complex roofing, ganged framing, and marriage walls... More
A Troubled Tiny House
Building a small wooden structure on a steel trailer without considering climate... More
Tracing Air Leaks With a Blower Door
A pair of home-performance experts show how to use a fog machine to do a... More
Log Cabin Envelope Makeover
How a New England contractor replaced a deteriorating log exterior with a new,... More
Airtight Attic Access
Every vented attic should have an insulated and air-sealed entry. Steve Baczek has... More
Controlling Air Infiltration
Lessons learned from blower-door-test failures. More
How Not to Kill Your Client
Energy saving is not the only reason for air sealing the garage wall. More
Air-Sealing a Masonry Party Wall
A masonry parge and fluid-applied membrane are the keys to performance. More
