A ‘Best Principles’ Cold Roof Assembly
Jeremy Kassel explains why belts and suspenders are needed when it comes to using... More
Air-Sealing the Lid
Nick Lehto shares his tried-and-true solution for ensuring an airtight ceiling... More
Avoiding Wet Roofs
Peter Yost explains the building science behind common moisture problems in attics... More
Island House Makeover — Insulating the Skin
In the teeth of a record-breaking winter, Thompson Johnson Woodworking wraps the... More
Details for Foam-Free Superinsulated Construction
The architects and Passive House consultants are working on a comprehensive set of... More
Buried and Encapsulated Ducts
Encapsulating ducts with at least 1 1/2 inches of closed-cell spray foam... More
Thermal Imaging With a Blower Door
Though it's impossible to seal every hole in an existing building to prevent air... More
Florida Researchers Take a Closer Look at Spray-Foam Roof Retrofits
University of Florida researchers are shedding new light on the strength benefits... More
Open-Cell Foams Approved
Several open-cell foams have been approved for the ICC-ES for use without an... More
Air-Sealing for Hot Climates
Excluding heat and humidity saves energy, improves comfort, and increases durability More
