Whether you use a manufactured insert or custom-fabricate the niche with... More
Tom Meehan says you can use either one, as long as you follow a few simple... More
Tile pro Tom Meehan explains how to prevent the backing on transparent glass... More
Tom Meehan explains how to detail the edge of a tile floor where it meets a carpet. More
How do you tile a floor to withstand spills of hot cooking oils and scalding water... More
Tile expert Tom Meehan explains how to choose between these two common... More
To avoid flexing that will crack the tile, bridge the joint between the old and... More
