Drywall Instruction
Making Backer Boards for Drywall Butt Joints
For faster finishing, try Aaron Miiller's simple method for making your own... More
Tags: Drywall, Drywall
Adding Water to Joint Compound?
For a smoother mix with fewer bubbles, drywall pro Lydia Crowder recommends adding... More
Quick Tray Ceiling
Myron Ferguson demonstrates how to upgrade a flat ceiling to an eye-catching tray... More
Best Premixed Drywall Compound
Wading through the choices for what works best in any given situation. More
Better Corner Nailing for Drywall
This detail provides better nailing for drywall and access to insulate wall corners. More
Avoiding Bathroom Drywall Problems
To prevent a bump in the drywall, don't screw through the tub/shower flange. More
Finishing Old, Unpainted Drywall
Why a stain-blocking primer may be needed before texturing or painting older drywall. More
Take the Misery out of Drywall Sanding
Sometimes evolution is slow, but right at the end takes a big leap. Drywall... More
Rough-in Tip for Wiring Prior to Drywall
A quick and easy way to keep over-anxious drywall hangers from burying wires. More
