Stairs Instruction
Rules for Wall-Mounted Handrails
A building inspector explains what the code says about returns at the ends of... More
Rules For Baluster Layout
Master stair builder Jed Dixon explains the art and science of laying out balusters. More
Diagonal Method for Stair Layout
After calculating the rise and run, take this extra step to guarantee an accurate... More
Q&A: Alternative Stair Design
When building a house with a loft accessed by a code-compliant stair, does a second, unorthodox, stair that leads to the same loft space have to comply with code as well? More
On the Job: Welded Steel Handrailing
Sleek but strong handrail; backyard face-lift; easier winders More
Building Over a Stairwell to Gain Space in a Small Second Floor
Making the most of a small upstairs More
Code-Compliant Winder Stair Layout
Winder stairs are a good solution when space is tight, but make sure you know the... More
Squeak-Free Stairs With Pocket-Hole Screws
On a new-construction job it's a good idea to give the drywallers a heads up; they... More
Outdoor Detour
Girder truss to the rescue; outdoor detour More
