Wall and Ceiling Finishes Instruction
Okay to Use Old Paint?
Paint pro Scott Burt explains how to evaluate an opened can of latex paint, which... More
Installing Crown Molding Solo
A veteran carpenter shares tips and techniques for installing long trim without a... More
Painting Sequence for Room Interiors
Always do the baseboard last and take care to cut in tight, straight lines. More
Repairing Cracked Granite at Sink Cutouts
Water leaking from a faulty sink installation can ultimately cause a granite... More
Fixing Faulty Roof Framing
A remodeler working on a master suite remodel that involves a cathedral ceiling... More
Drying Rack for Staining Shingles
Manny Silva shows how a lightweight rack built from scrap materials and fishing... More
Drywall Skim-Coat vs. Veneer Plaster Finishes
Myron Ferguson explains the difference between a Level 5 drywall finish and a... More
Hand Sanding: Necessary Evil Made Tolerable
At times, power sanding is impractical and we need high level manual options for... More
How to Grout Slate Tile
Michael Byrne on grouting and cleaning slate and other textured tiles. More
Choosing the Right Grout
When should you use a cement-based grout, and when is epoxy grout a better choice?... More
