Applying finish to the floor at the start of a job is unconventional, but it saves... More
A floor system that complies with the IRC's deflection limits can still feel... More
The prep work is the same as for unfinished strip flooring, but the installation... More
We were wrapping up the latest in a series of renovation projects on a suburban Maryland split-level home when I casually mentioned to the owner that her Thanksgiving family gatherings would be a lot more enjoyable if her small kitchen weren't separated from the dining and living areas by a wall. More
Assessing the moisture content and surface condition of the slab was the critical first step. More
To ensure a long-lasting installation, use a membrane and a movement joint. More
A high-tech floor coating, slat wall, and cabinets transform a single-car garage... More
Before installing flooring over concrete, do a calcium chloride test to make sure... More
