Wood Flooring Instruction
Dimensional Changes in Wood
How to calculate the changes for whatever pieces you might choose. More
Fitting the Final Floor Board
Learn how to use a scribe block to get a perfect fit every time. More
Expansion Space for Wood Floors?
Many of the “rules” regarding wood flooring installation are based on mythology... More
Nailing Wood Flooring
Hammers, pneumatic nailers, and nailing machines all have their pros and cons. More
Finishing Laminate Floors
Installing hardwood over a concrete slab requires extra care and special materials... More
Treat or Replace Pet-Stained Subfloor?
Should subflooring that has been stained with dog urine be torn out and replaced before a new hardwood floor is installed? More
Mesquite Hardwood Floors
The most common choice for hardwoods in the houses I build has been white oak, so when I found out the architect had specified Mesquite, I knew I needed to video the process. More
Installing Hardwood Flooring Over Vinyl
Hardwood flooring can be installed over existing sheet vinyl if key conditions are met More
Managing Moisture Content of Wood Flooring
You can't prevent swelling and shrinkage problems by just letting the flooring... More
Cure for Cupped Hardwood Flooring?
To fix the floor, you have to find and eliminate the moisture imbalance that is... More
