To prevent a siphon from forming, make sure the drain pipe connects with the vent... More
Why you should connect a dishwasher drain line to a sink drain instead of directly... More
Tankless water heaters are fantastic units but they do need more care &... More
Plumbing is a huge topic and isn't easy to cover in one blog post but here's a few... More
What are the rules for venting a sewage ejector tank that services basement... More
Noisy pipes and the sound of rushing water inside the walls can be really annoying. Here's one easy way to totally eliminate the noise of water inside your drain pipes. More
If you've ever installed a Clothes Dryer you know that the vent at the back is in... More
If you have hard water and use a tankless water heater, sooner or later you will need to flush your unit. More
Q: In my area, only black iron pipe is allowed for gas lines. Is there a problem with galvanized pipe? More
