Efficient Hot-Water Piping
Save time, water, and energy with smarter layouts and by sizing the hot-water... More
Faster Hot Water
Learn how to save water, energy, and time with an on-demand hot-water circulation... More
Retrofitting A Whirlpool Tub
A bathroom renovation specialist explains how to select and install a jetted tub... More
Using CPVC Piping for Fire Sprinklers
Residential sprinklers systems are unobtrusive and effective, but are not usually installed because of cost. One way to make them more affordable is to use plastic piping, as described in this article by a California fire marshal. More
Plumbing Pitfalls For Bathroom Remodels
From corroded pipes and antique fixtures to limited access and impossible working... More
Fighting for Inches: A Guide to Small Bathroom Design
Fitting all the fixtures into a usable space is the main challenge of small bath design. A house designer describes her favorite small-space floor plans. More
Common Plumbing Service Calls
The twelve most common residential plumbing problems, and how a master plumber... More
Installing Jetted Tubs
Jetted tubs require careful framing, easy access to the pumps and motors, and a mortar bed to dampen vibration. This step-by-step installation guide by a veteran remodeler shows you how to do it right. More
