Troubleshooting a Failed TPO Roof
On a low-slope roof, a single flaw can cause big problems. Here's a case study in... More
A Versatile Fluid-Applied Roofing Solution
An alternative to EPDM and other single-ply roof membranes, Acrylabs is a... More
Repairing Stone Patios Over Living Space
Thorough waterproofing is essential for a leak-free job More
Low Slope Roofing: Lessons Learned
Choosing materials wisely is a good start. But success comes from careful... More
Draining Low-Slope Roofs
Poor drain design along with inadequate pitch can result in catastrophic water... More
Getting Started with TPO Roofing
This tougher alternative to rubber membrane can be installed without adhesive More
Fall Protection for Roof Work
To comply with OSHA safety rules, you need the right equipment, but you also need... More
Reroofing With EPDM Rubber
Roll roofing was the wrong material for the flat roof under this second-story deck. More
Installing a Green Roof
Interlocking pre-grown panels add little dead load to the roof. More
Products
Housewrap; asphalt roofing More
