A Multilayered Solution
After the self-adhering housewrap and 30-lb. asphalt felt paper are applied, a drainage matrix (with gray-colored filter fabric) is installed. Here, Obdyke Slicker Max drainage matrix is used, though on similar masonry veneer projects, the author also uses Mortairvent. The stone veneer is re-installed, secured with stainless steel masonry anchors.
