Sized for nominal 2-by lumber and designed to install with fewer, shorter nails, the H1A hurricane tie from Simpson Strong-Tie is rated for high allowable uplift and F2 loads to meet building safety needs in seismic and high-wind regions. The U-shaped tie holds a rafter or truss on both sides, providing lateral load resistance, and embossments add stiffness for improved performance; flanges can be installed facing inward or outward. The H1A is available in standard G90 galvanization or with Zmax coating for corrosion resistance. strongtie.com
More about Simpson Strong-Tie Co.
Find products, contact information and articles about Simpson Strong-Tie Co.
