Festool ETS EC 125/3EQ
After months of testing Festool's new ETS EC 125 sander, finish foreman and restoration specialist Tim Leahy weighs in on what you get for your money.
ETS EC 125/3EQ Sander
Festool
Dust Extraction Port27 mm
Motor TypeEC–TEC Brushless Motor
Pad Size5″ Diameter (125 mm)
Power Consumption400 watts (3.3 amps, 120 V AC)
Sanding Stroke1/8″ (3.0 mm)
Speed6,000 – 10,000 RPM
SystainerSYS 2 TL
Weight2.6 lbs. (1.2 kg)
I have owned Festool sanders for more than 10 years, starting with the larger ETS 150 with a 6-inch diameter. I then added a smaller, 5-inch pad model. The combination of excellent ergonomics and vibration reduction that puts other sanders to shame makes these sanders “must haves” for any type of finishing operation.
Earlier this year, I was invited to try the new ETS EC 125/3EQ coupled with the CT Mini dust extractor. Both pieces of equipment were built with the user in mind, with convenient storage for accessories, cords, hoses, and sandpaper. The Systainer system ability to carry a powerful vacuum and a sander (or more) with everything needed in one hand is a nice bonus. I also added a second sander to the setup—which added to the weight a bit—and I had everything needed for two workers to complete a big sanding job.
The sander is powerful, thanks to the EC-TEC brushless motor, but it remains smooth and vibration free. I often restore and repair high-end cabinetry and paneling, and some of that work is in the field. When coupled with the dust extractor, the sander sands almost without creating any dust whatsoever, which is a real plus.
The lower profile of this newer version compared with that of my older ETS 125 3 allowed me to get into some smaller spaces. The pad clears the handle a bit more, too, which makes it possible to sand right to the edge of work, no matter the position of my hand. The sander accepts all Festool abrasives, including GRANAT and RUBIN. I use the GRANAT paper for most of my work on unfinished wood, or when I am refinishing. The paper is long-lasting; I get very little if any loss of abrasive particles from the paper, and it rarely clogs up if the finish being sanded is cured.
On one particular job, I was working on a master-suite closet system comprised of cabinets made of soft maple cases and paint-grade face frames, drawer fronts, and doors. Here I used #180 to remove pencil lines, smudges, and milling marks. The sander performed well, yielding a smooth surface ready for paint. I used #220 to smooth the primer coat and #400 between finish coats. On older barn doors made of heart pine, I needed a more aggressive removal, and the sander didn’t disappoint. After Infra-red paint removal, we needed to produce a surface prepared for clear finish as part of this historic restoration. The #100 really made quick work of leveling the wood to a uniform appearance and texture. Subsequent sanding with #120 then #150 smoothed it perfectly without visible sanding marks. Newer pine that is much softer would have needed another sequence of #180 or #220, especially if you were staining it.
The only drawback I found to the sander is the balance when fitted with the vac hose. With the sander’s lightweight design (surely a good thing), the hose tended to pull down on the rear port area a bit when sanding on a horizontal surface, which can cause the pad edge to create a swirl. Likewise, when I do overhead work, the hose pulls on the port, and the front edge of the pad may become pressured. To alleviate this, I simply work the tool with both hands, and the issue is solved.
Cost: $385
www.festoolusa.com
SPECS:
Tim Leahy
A former finishing foreman, Tim Leahy is the director of Architectural Finishes at Kirby Perkins Construction - a Newport, RI-based company that builds custom homes, and preserves and restores historic properties throughout Southern New England. His teams have created and restored many types of surface coatings on a variety of historic restoration projects throughout Southern New England, as well as in Williamsburg Va, and Charleston SC. Kirby Perkins also utilizes state-of-the-art technology and advanced coatings for new work on almost any substrate. When not at his desk, in the shop, or in the field, Leahy enjoys spending time with his wife, repairing and refinishing antique furniture, ocean kayaking, cooking, and attempting to improve his golf game.
