Although multi-tools have been around for years, one manufacturer - Fein - had the market pretty much to itself until recently. Over time, as builders and remodelers came to appreciate what these diminutive tools and their attachments could accomplish, demand surged - and now there are several companies producing them. For this review I tested four cordless models (powered by 12-volt lithium ion batteries) - the Bosch PS50, Dremel 8300, Milwaukee 2426-20, and Ridgid R82235 - and four corded models: the Bosch MX25E, Dremel 6300, Fein FMM250Q, and Rockwell RK5108K.
Attachments Are the Key
Considering its many capabilities, the multi-tool is a remarkably simple device. Its motor twists a short, perpendicular spindle back and forth through a seemingly insignificant 3-degree arc. But paired with an extensive array of specialized attachments, that tiny oscillation is able to carry out a surprising amount of work. Although some multi-tools are sold by themselves, they're most often packaged in a kit with various attachments. Fein, for example, gives buyers a choice of three different configurations; Rockwell offers kit sizes that range from 39 to 100 pieces.
Attachment styles and cost. Besides the basic triangular sanding pad, popular attachments include saw blades for undercutting jambs and sawing through nails, scrapers for caulk and adhesive, carbide grout cutters, rasps for grinding thinset, and miniature coping saw blades. The list of available attachments - and the number of jobs they can tackle - is virtually endless. The same goes for the amount of money you can spend on them. The price of a segment (half-moon) saw blade ranges from $8 for a light-duty Dremel to around $27 for Bosch's bi-metal flush-cutting variety. You'll pay $25 for a triangular carbide rasp from Rockwell, $35 for one from Fein. Every manufacturer except Milwaukee offers its own line of attachments.
With most multi-tools, swapping attachments requires removing a machine screw with an Allen wrench (top left). Dremel's Quick Fit attachments have an open-ended mounting hole that lets you simply loosen the screw, but not remove it altogether (top right). Swap-outs are easiest with the Fein: You just flip a lever on the top of the tool head to release the pin securing the attachment (bottom).
Catch and release. There are three different ways to secure an attachment to a tool's oscillating spindle. Most of the tools rely on a machine screw that's inserted through a hole in the attachment and fastened with an Allen wrench. This method is effective but cumbersome and can lead to dropped pieces, lost wrenches, and enormous frustration if you happen to be wearing gloves.
Dremel's "Quick Fit" feature makes changing attachments a little easier: Instead of a hole, its attachments have an open-ended slot that lets you swap them out without removing the screw.
The Fein FMM250Q has the best locking design of all: an easily accessible tool-free flip lever that instantly locks or releases the bolt holding an attachment to the spindle. The entire process takes just seconds and doesn't require a wrench - a real asset if you change attachments often.
These mounting styles match a tool with its in-house brand of attachments, but most manufacturers also offer adapters that allow you to use tools and attachments from different companies (see "Adapters Offer Mix-and-Match Options").
Cordless Is Legit
On the whole, the cordless models were impressive performers. If you expect to operate a multi-tool for hours at a stretch, you probably need a plug-in model. But if you mainly use a multi-tool as a problem-solver, the convenience of cordless is hard to beat.
The Bosch PS50 shows its battery's charge level with the touch of a button.
Runtime. Unless you've got a slew of replacement batteries, the amount of work you can accomplish on a single charge is probably the most important criterion for choosing a cordless tool. The second most important is the charger's ability to work quickly. (Three of the four cordless kits I tested included a spare battery, Ridgid being the exception).
The author's cutting jig provided an objective way to compare the power of the eight multi-tools in the test.
To test battery endurance and recharge time, I gave the four cordless competitors a typical multi-tool assignment: cutting 3„4-inch by 4 9„16-inch pine jamb legs. The Bosch and Dremel made 19 complete cuts before the battery ran down, the Ridgid made 22, and the Milwaukee made 25.
Bosch's roomy case has storage compartments for various attachments, batteries, and a charger (left). Ridgid's skimpy bag has little room for extras (right).
Then I recharged the batteries. Ridgid won this trial: Its charger renewed a fully discharged battery pack in 27 minutes. Bosch and Milwaukee tied for second with about 30 minutes each. The Dremel charger required 51 minutes.
Battery fuel gauges. I've grown so dependent on cordless tools that display a battery's remaining charge that I find myself avoiding models without this convenience. In this test, only the Ridgid lacked a battery indicator light. I liked the Bosch's push-button display best; the Dremel and Milwaukee lights work only when the tools are switched on.
Bosch PS50-2B $185; boschtools.com
This Bosch finished a mere whisker behind the Milwaukee as the best cordless performer. Although it was the most powerful cordless tool, it had the shortest runtime. It features an outstanding grip with easily accessible controls, and a battery fuel gauge controlled by a push button on the tool body. Attachment changes require a bolt and wrench.
Milwaukee 2426-20 $150; milwaukeetool.com
The Milwaukee narrowly edged out the Bosch as my favorite cordless multi-tool. It ranked second in power but ran the longest on a single battery charge. This tool accepts Bosch attachments, and its well-designed adapter accommodates almost everyone else's attachments as well. The tool body is a no-frills cylinder that provides a very comfortable grip. The battery fuel gauge consists of a series of lights that briefly illuminate when the tool is first switched on; it's not as handy as the Dremel's but works well enough.
Dremel 8300-01 $110; dremel.com
Although it ranked as the least powerful tool in the pack and tied for last place in cordless endurance, the Dremel was a pleasure to use. I found its grip exceptionally comfortable, and the control switches were the most convenient. The Quick Fit attachments made swap-outs fairly quick. The charge status lights are constantly illuminated when the tool is running, so it's easy to predict when the battery is about to be exhausted. This tool would not be my choice for demanding labor, but it is more than adequate for light-duty service.
Ridgid JobMax R82235 $100; ridgid.com
Hands down, the Ridgid was the most unique tool in this review. Its removable multi-tool head is part of a system of interchangeable heads that allow the tool to perform a wide variety of tasks (see "A Multi-Head Tool"). Unfortunately, if you purchase these accessories, you'll have no place to store them in the tiny kit bag. The Ridgid was the only tool with an LED task light and was the sole cordless kit that did not supply two batteries. It was also the only tool with a variable-speed trigger. Overall, when outfitted as a multi-tool, the Ridgid is a light, capable performer that finished second in the battery endurance test.
Corded Models
Bosch MX25E $195 (MX25EK-33), $155 (MX25EC-21); boschtools.com
I tested an early demonstration model of the MX25E. Bosch now offers this tool in two kit versions. The MX25EC-21 includes a carrying bag and 21 attachments (15 of them sheets of sandpaper); the MX25EK-33 has a hard-shell case and 33 attachments (25 of them sandpaper). Either way, this is an excellent machine. It matched the Fein as the most powerful and heavy-duty of the eight multi-tools I tested. It is comfortable to grip, though less so than its cordless sibling. A convenient rubber holder on the cord helps prevent the Allen wrench from getting lost. My sole complaint is that the variable-speed control wheel is inconveniently placed under the power cord at the rear of the tool body.
Fein FMM250Q Top Plus $400; feinus.com
The Fein is an excellent heavy-duty tool that tied for the top spot in overall power. The tool body is a bit chubby and could use more rubber on its belly to improve the grip, but these ergonomic shortcomings are more than outweighed by its outstanding tool-free attachment feature. If you change attachments frequently, you'll want this tool. I also really liked its sanding capabilities and extra-long (16-foot) power cord. Its tiny variable-speed control dial, however, was the worst of the bunch.
Dremel 6300-04 $100; dremel.com
This model is very similar to its cordless brother. It ranked last in power among the corded tools but is undeniably comfortable and easy to use. Its controls are similar to those of the corded Dremel and it uses the Quick Fit attachment system. The stiff and kinked power cord was a minor annoyance because it never loosened up. Overall, this model is a good tool for less-demanding tasks.
Rockwell SoniCrafter RK5108K $220 (smaller kit sizes also available); rockwelltools.com
Although less well-known than its competitors in this test, the Rockwell is a solid no-nonsense model capable of tackling any multi-tool task. The tool body provides a good grip, and the variable-speed control is easy to adjust while cutting. I liked the reasonably long (10-foot) cord, but the wrench holder is located on the cord's strain-relief area, which means the wrench has to be removed and replaced for every attachment change. The 100-piece kit has many excellent attachments (though several - like the polishing pads - might see little use).
More about Bosch Power Tools
Find products, contact information and articles about Bosch Power Tools
