Rolair JC10 Compressor
Photographer: Dave Gilo
StoryID
K4_11211
ToolNumber
1286
ComponentId
tcm:78-1885796
With its small size and whisper-quiet motor, Rolair’s JC10 oil-less compressor just might be ideal for your trim needs. Because of the low-speed motor, the compressor operates at only 60 dB, the noise level of normal conversation. But productivity isn’t lost, thanks to a dual-piston system filling the 2 1/2-gallon steel tank. The 1-hp unit weighs 38 pounds and has a roll-cage design and a cold-start valve for easy cold-weather starting. It produces 2.35 cfm at 90 psi. Price: $220. 920-349-3281. rolair.net.
Doug Mahoney
