Contents:
Domestic Water
Home Automation
Manufactured Fireplaces &
Accessories
Faster Hot Water.
Homeowners and
businesses can waste 25 gallons of water every day waiting for
it to get hot, but you can shorten the wait and reduce the
unnecessary consumption with a circulating pump. Circulating
pumps temper the water by periodically mixing hot water into
the system. Systems like the Plumb and Plug Cartridge
Circulators from Taco use a digital timer to cycle the pump on
and off as many as ten times a day to coincide with periods of
peak water usage. Taco also makes a version with an analog
timer with similar capabilities. The analog version has a list
price of $275; the digital version has a list price of
$295.
Taco, 401/942-2360,
www.taco-havc.com.
Broken Pipe Protection.
Broken
water pipes or leaks can ruin a home in a hurry. Stopping leaks
before that happens is the rationale behind Liquid Breaker.
Similar to a conventional breaker panel, the monitoring system
uses small sensors connected to shut-off valves that cut the
supply of water to the offending pipe or fixture before it's a
problem. Competitive products rely on valves that can become
stuck from inactivity, but Liquid Breaker's valves are actuated
with greater pressure to overcome scale or corrosion in the
valve body. In addition, the system shuts off water only to the
leaking pipe or fixture, without shutting down the whole house.
Valves can be hard-wired or controlled with RF
transmitters.
Liquid Breaker, 866/444-0212,
www.liquidbreaker.com.
All's Well.
Few things are as
disturbing as running out of domestic water, and it happens all
too frequently to homeowners relying on a low-yield well. In
most cases, the problem with low-yield wells is they don't
collect groundwater fast enough to keep up during times of high
demand. The Well Manager uses a pretty simple method to produce
more water from a low-yield well. During the workday and at
night, when the household wouldn't ordinarily call for water,
the Well Manager intermittently activates the well pump to fill
a nonpressurized tank for later use. When the pressure switch
calls for water, it gets it from the nonpressurized tank first,
not from the well. Electronic controls monitor operation and
prevent running the well dry. According to the manufacturer,
the Well Manager can provide enough water for a family of four
from wells producing as little as .1 gpm. Prices start at about
$4,000.
Reid Plumbing Products, 800/211-8070,
www.wellmanager.com.
Home Automation
Low-Tech Light Control.
Home
automation doesn't have to mean expensive controls and the
ability to call your oven from the road. The Sensor Plug is a
simple plug-in device that automatically turns on a connected
device whenever somebody enters the space. Once activated, the
device will stay on for 15 minutes unless the motion sensor is
reactivated during that time, which starts the counter once
again. It works from up to 20 feet away and with devices of up
to 500 watts. It sells for $15.
Andev, 845/297-8001,
www.sensorplug.com.
Sexy Switches.
Providing your
customers with lighting controls that make their life easier
without bogging them down in technology they don't need or
understand is a delicate balance. If you're looking for a
lighting controller that isn't too scary, you might consider
Home Touch. According to the manufacturer, Home Touch uses a
communication technology similar to x10 but more reliable.
Switches can turn lights on and off from up to 1,000 feet away
using the home's existing wiring. The controllers are available
in white, almond, ivory, and black in both Decora and Home
Touch's own designs. A 2,000-square-foot house with ten modules
usually costs about $3,000 installed.
LiteTouch, 888/548-3824,
www.litetouch.com.
Mood Swings.
For those who enjoy
creating interior lighting scenes, the Toscana Deluxe
Programmer from Leviton offers up to 64 whole-house lighting
schemas. The DHC (Decora Home Controls) device uses x10
protocol and can handle up to 256 individual devices. It
includes set-up wizards for easier programming and includes
Leviton's Intellisense Technology, which reduces signal
problems caused by line interference. The controller sells for
about $480, and compatible devices average about $50 per
load.
Leviton, 800/833-3532,
www.leviton.com.
Automation in a Box.
If you're
building a customer's dream vacation home, you might suggest
the Shell Home Genie. The home management system allows
homeowners to control their heating and cooling, turn on lights
or appliances, and capture video from a remote location using a
broad-band internet connection. Available contact switches
allow monitoring of doors, windows, file cabinets, and even the
collection of fine wine in the cellar. Starter kits sell for
$600 on the company's website.
Shell Energy Services, 866/677-4355,
www.shellhomegenie.com.
Manufactured
Fireplaces & Accessories
Stand Tall.
The short firebox
common to many manufactured fireplaces tends to look small and
boxy when compared to a classic masonry fireplace. The Colonial
Wood-Burning Fireplace from Lennox has a noticeably taller
front opening that gives it a more traditional appearance. It
also has an interior that looks more like actual brick and a
front that minimizes exposed sheet metal. Builder-friendly
features include built-in nailing tabs and an integral damper.
It uses 10-inch, double-wall flue pipe and has a base price of
about $1,400.
Lennox Hearth Products, 800/953-6669,
www.lennoxhearthproducts.com.
Plug In.
I remember a childhood
friend's family setting up their electric fireplace every year
so they could have a place for hanging the stockings and
snapping holiday photos. Unfortunately, the light bulb and
rotating drum meant to simulate flames wasn't very convincing,
but times have changed. In fact, I did a double take when I saw
the OptiFlame at this year's Builders' Show. The electric
fireplace is available in free-standing and built-in models
from 23 inches to 48 inches wide and eliminates the hassles of
installing a gas line or flue. It seems like the perfect
fireplace for homes in the city and for rooms that need a
little romantic boost. It's even available with remote control.
Generally, prices are in the $500 to $750 range.
Dimplex, 800/668-6663,
www.dimplex.com.
Rock Solid.
I think of stone
mantels as a defining detail in Edwardian manors and medieval
castles, but they also make a nice addition to more modest
properties. Forshaw makes a line of Stone Mantels that install
quickly and easily — without a mason. They're secured
to the wall with thinset, and they're sized for most
factory-built fireplaces. Prices average about $900. The
"Greek-inspired" Aegean is shown.
Forshaw, 800/367-7429,
www.forshaws.com.
Top Hat.
Forshaw's Chase Top
Flashing is not a fireplace accessory that homeowners will
display with their brass tools and bellows, but it's at least
as important. Designed to cap off-site-built wood chases, it
makes installing a manufactured fireplace easier because it
will save at least one trip to your sheet-metal fabricator. The
preformed flashing is made from 26-gauge, G-90 galvanized steel
and has an upturned lip that encircles the flue for better
water resistance. It's available for flues of from 5 3/4 inches
to 16 inches outside diameter with one, two, or three holes.
Sizes go from 3x3 feet to 4x8 feet. One-hole chase tops run
about $25.
www.forshaws.com.
Breathing Room.
While fireplaces
are good for many things, improving indoor air quality doesn't
usually jump to mind as one of them. The FreshAir Gas Fireplace
is a little different. It uses a heat-recovery ventilator to
extract heat from exhaust gases and to introduce fresh air into
the building at the same time. The balanced combustion reduces
the buildup of interior humidity and the spilling of exhaust
gases into the living space. To make installation easier and to
allow greater flexibility of placement, the ventilator can be
located up to 54 feet away from the firebox. Installed prices
run about $6,000.
Heatilator, 877/427-8368,
www.freshairfireplace.com
