Getting Into Modular Construction, continued
Marketing, Design, and
Financing
In my experience, modular-home buyers are a tech-savvy group,
and many of them have spent quite a bit of time researching the
subject on the Internet by the time I encounter them. In fact,
many of my initial customer contacts come about through the
Internet, through either my own website or modular
manufacturers' sites.
Here's how it works: As potential customers browse for their
ideal house plan from various manufacturers, they often request
additional product information by filling out electronic forms.
Manufacturers are wholesalers and aren't interested in dealing
with retail sales, so they pass the information on to builders
who operate in their area. Because I build homes from several
different manufacturers, I'm not dependent on electronic leads
from any one firm.
Another source of leads is a site run by an association of
modular builders, modularcenter.com. It offers information on
modular construction, as well as links to manufacturers and to
builders like me. Most potential buyers who go to the Internet
end up there eventually, because typing the words "modular
home" into any search engine will lead them there. The annual
fee for a listing is $100 per year, plus a small percentage of
each sale made from a lead supplied through the site.
Design options. Each modular manufacturer has
its own portfolio of stock plans, and once they've settled on a
particular manufacturer, many buyers are happy to choose a
model directly out of the catalog. But manufacturers have
learned that if they want to move into the territory that's
always been occupied by stick builders, they have to give
buyers what they want. If the customer provides a print or a
floor plan, any good modular manufacturer can redesign it as a
modular. The main design limitation has to do with moving the
modules to the site. If the modules are kept to 13 1/2 feet
wide or so, transport isn't a problem. State laws vary, but
once you get up to 16 feet in width, you usually need a state
police escort in front and back as the module travels to the
site, and that gets expensive. There are also architects who
specialize in custom modular designs, although that isn't my
usual market.
Working with the bank. Like conventional homes,
modulars are financed through standard home mortgages and
appreciate in value at the same rate as comparable stick-built
homes. (Don't confuse modular houses with HUD-code houses,
which banks typically treat as personal property like a car or
a boat.) Even so, financing a modular is somewhat different
than financing a conventional home. The bank typically makes a
10% down payment to the manufacturer when the house is ordered
and pays the remaining 90% on delivery. Normally, the bank
sends a representative to the site with a check on the day the
home is delivered, because the driver won't unload it from the
truck without payment. As the contractor, I get paid by a
standard draw, starting with the completion of the
foundation.
Foundations and Setting the
Modules
I put my houses on a poured foundation with a full 8-foot
basement because that's what buyers in my area want. We have a
very good foundation sub who takes care of all the site work:
He excavates, pours the garage slab and foundation, and even
sets the plates. Accuracy is important here. You can fudge a
stick-built house if the foundation is a little off, but that's
harder to do with a modular. When you set the modules down, you
want to be sure they're going to fit.
The modules arrive on steel carriers towed by tractor-trailer
rigs; they're met by a four- or five-person set crew and a
local crane and operator. The manufacturing company can provide
its own crew, but I prefer to hire the same setting sub every
time.
From rigging to roofing. The back module usually
goes on first. It's strapped for the lift, craned off the
carrier, and carefully set down on the foundation. The set crew
places support posts under the central girder and erects the
rear half of the fold-down roof trusses. The front section of
the roof is raised before the front module is strapped and
eased into place. This leaves a gap at the ridge, which is
closed off with piggyback trusses that are craned onto the roof
along with the necessary OSB sheathing and shingles. The whole
process, from the arrival of the truck to closing off the roof,
takes about half a day.
Once the roof section is erected by
the crane, folding truss webs lock it in position. Next, the
front module is craned onto the foundation and butted tightly
against the previously placed rear unit. The crane also makes
short work of positioning the piggyback trusses, sheathing, and
shingles needed to complete the roof. The set crew stick-builds
the garage, which the author finds more cost effective than
shipping in a modular garage.Stick-built garages. Factory-made garages are
available, but I've found that they're not cost effective.
Compared to a house module, which is braced by interior
partitions and a rigid floor assembly, a garage is basically a
big flexible box with no bottom. The factory has to add a lot
of expensive temporary bracing to stiffen it for transport,
which offsets the cost savings of modular construction. I
eliminate that added cost by having the set crew stick-build my
garages.
Mechanicals and Finish
The modules are fully wired at the factory, so all the
electrician has to do is hook up the wiring between modules,
install the prewired main panel in the basement, and connect
the service entrance cable. The plumbing fixtures and concealed
supply and drain lines are also installed at the factory. The
factory can do the overhead plumbing in the basement, except
for the interconnections between modules, but I save some money
by doing the overhead supply plumbing myself. I have the
manufacturer stub all the fixtures into the basement, and I
finish the installation with the Manabloc home-run system,
which uses PEX tubing. My plumbing sub finishes the drain
lines.
Some modular manufacturers can install a complete heating and
air-conditioning system at the factory, but I prefer to have my
own hvac sub install a gas-fired forced-hot-air system after
the house is on site. The house arrives with precut register
openings in the floor. My modular homes perform well enough to
receive an EPA five-star rating, which translates to an
expected energy cost of $432 annually for a 1,500-square-foot
home.
Flooring, trim, and siding. The factory hangs
most of the doors, installs interior trim, and installs most
types of finish flooring, including laminate, vinyl, and
hardwood. Carpeting can also be factory installed, although I
prefer to do that after assembly. There's still a good deal of
trim work to do where the sections join. My other key sub, in
addition to our foundation guy, is the carpenter who handles
all the interior and exterior finish work, including
siding.
Problems and Limitations
Despite its advantages, modular construction isn't trouble
free. I spend much more time than I would like fixing drywall
cracks, rehanging doors, repairing damaged trim, and dealing
with other punch-list items. Some of those problems are
unavoidable when you ship a house over hundreds of miles of
road, but I don't think they should be seen as the builder's
problem. Unfortunately, few manufacturers have the staff to
deal with these kinds of customer-service issues in a timely
manner. It can take so long to get the factory to address or
credit the repairs that I usually end up putting on my tool
belt and fixing them myself. That keeps things moving, but it
means I end up absorbing the cost of repairs. I'd like to see
more manufacturers follow the lead of one Michigan firm, which
gives a blanket 3% credit to fix minor problems when the home
lands on the site.
Getting options outside of the respective manufacturers'
standard construction process is also difficult. I suspect
that's because modular construction is an assembly-line process
and lack of either space or training prevents deviation from
the norm. For example, I can get hip roofs from only one
manufacturer and 9-foot walls on ranch-style homes from only
one other. In a site-built home, there is more flexibility of
materials as well. Manufacturers make arrangements for volume
discounts with material suppliers, and that keeps the cost
down.
This also means that some of the products used by modular
builders, such as roofing shingles and siding, may differ from
those available through the usual commercial channels. If you
don't plan ahead, that can make it difficult to match
materials, and nobody wants to spend half the day driving
somewhere to get the right color J-channel. Where possible,
it's best to specify branded materials that can easily be
matched locally.
Doug Holdridge is a home builder in Perrysburg,
Ohio.
