Green Products
US GreenFiber. Cocoon insulation, a sprayed-in, stabilized cellulose product, is made from a minimum of 80% recycled post-consumer paper. The remainder of the product consists of fire retardants and a stabilizing adhesive that prevents settling after application. Cocoon provides an R-value of 3.7 per inch, the maker says. 888.592.7684. www.cocooninsulation.com.
FiberTech Polymers.
TimberWolf composite fencing products are made of 100% post-consumer recycled materials. Offered in both western cedar and California redwood colors, the fencing has the look and feel of wood, won’t fade more than 20% within the same color family, and won’t fade to gray, the maker says. Both panel systems and individual components are available in several styles. 888.248.9653. www.fibertechpolymers.com.
EnviroGLAS.
The company’s terrazzo products consist of 100% post-consumer and post-industrial recycled glass blended with a pigmented epoxy resin to create custom-colored floors (EnviroPLANK), countertops (EnviroSLAB), and other surfaces. The surfaces are naturally chemical- and bacteria-resistant and produce zero VOC off-gases. 888.523.7894. www.enviroglasproducts.com.
AlterECO.
The PureGrass premier cabinetry system uses 100% bamboo panels for cabinet cases, and features dovetailed bamboo drawers, dampening hinges, undermount drawer slides, and a low-VOC finish. The company also offers WoodGrass and WheatGrass systems with different materials and construction methods. 415.331.8342. www.bamboocabinets.com.
Follansbee.
KlassicKolors is a pre-painted zinc/tin coated roofing sheet offered in an extensive palette of colors. Its base sheet is coated with the company’s patented ZT (zinc/tin) alloy and then painted with solar reflective paint coatings. The ZT alloy provides enhanced durability and extends the life of the metal for many years, even if the painted surface is breached, the maker says. KlassicKolors comes with a 30-year warranty. 800.624.6906. www.follansbeeroofing.com.
For more product information, visit ebuild, Hanley Wood’s interactive product catalog, at www.ebuild.com.
