Installing Venting Skylights Without the Headaches
What Pros Need to Know
Skylights used to have a reputation among some builders as a risky detail, fearing too many callbacks, too much potential for leaks. However, the truth is that modern venting skylights have come a long way, and today’s systems are easier to install, more reliable and far more efficient than many realize.
For remodelers and builders looking to add ventilation and natural light without increasing the mechanical load, venting skylights are one of the most effective passive solutions available. They allow warm, stale air to rise and exit the home naturally, pulling in cooler air through lower openings in a classic stack-effect setup. And when installed correctly with today’s flashing kits and curb systems, they’re every bit as durable and watertight as a standard roof penetration.
Same Framing, More Function
One of the biggest misconceptions in the field is that venting skylights require special framing or added labor. In reality, most modern models are designed to install just as easily as their fixed counterparts. The rough opening is the same, and the installation process follows familiar steps without a learning curve. With pre-flashed curbs or step flashing kits now standard on many models, weatherproofing is also faster and more foolproof than it used to be.
No Electrician Needed
Wiring has traditionally been the holdup for some builders considering venting models. Running electrical lines, opening up walls and coordinating with a sub can make what should be a one-day job drag into a longer process. But there’s good news: Solar-powered units are making electric-free operation a standard feature. These skylights use a small, integrated solar panel and rechargeable battery to power the venting motor and remote-controlled functions, eliminating the need for wiring, an electrician and workflow disruptions. Simply mount the solar panel to a pre-mounted bracket, connect the wire cables together and turn it on. That’s it.
Don’t Overlook the Shade
Shades are one feature that homeowners often overlook before installation. In fact, many builders report that clients come back wishing they’d included them from the start. For that reason, the leading skylight company in the world recently made shades standard in almost every model. VELUX’s Skylight System includes a pre-installed, solar-powered shade that operates by remote control. These shades not only give users total light control, but they also significantly improve thermal performance. For example, integrated shades can improve U-values by up to 45% and reduce solar heat gain coefficients by about 19%, helping meet energy goals without the need for tinted glass or window film.
What It Means for Your Next Job
If you haven’t installed a skylight recently, it might be time to revisit your assumptions. With improved installation systems, solar-powered operation and integrated shade options, headaches are a thing of the past. The VELUX Skylight System packages all of these features into a single, streamlined unit that installs cleanly and operates independently from the home’s wiring.
For remodelers and builders seeking to incorporate natural light, passive ventilation and long-term client satisfaction with minimal fuss, venting skylights are worth a second look.
