Beam Q PowerTeam Central Vac With EasyReach Hose
Beam. Central vacuum systems offer convenience, but a 30-foot hose can be unwieldy. The Beam Q PowerTeam is now equipped with an EasyReach retractable hose that stores inside itself. Unlike hose management products that require inside-the-wall installation and separate hoses for each inlet valve, the Beam Q Easy Reach hose can be moved from inlet to inlet. The outer hose is just 13 feet long. When more hose length is required, the user can release an inner hose to reach the full 30 feet. The push of a button on the handle restores the hose to its 13-foot length by using the vacuum’s own suction to retract the inner hose. 800.369.2326. www.beamvac.com.
Lauren Hunter
