Available with either horizontal cable or picket infill, the RailFX Oasis Railing System is fabricated from extruded aluminum in a textured black finish in 36- and 42-inch heights. For cable infill, the posts are predrilled for cable installation and can be spaced up to 8 feet apart with an included cable brace (the maximum unsupported span for cable is 4 feet); an insert slides into a top rail to secure cable braces. For picket infill, the balusters install in preformed holes in top and bottom rails. The 3-inch posts for both infill options can be surface-mounted only. railfx.net
