Insulation That Works
In more than 25 years of consulting with builders on ways to avoid callbacks, Steve Easley has spent his time solving problems related the heat and moisture transfer because this is where contractors — even very good contractors who deliver well-appointed homes to the coastal elite — most often get things wrong. With tougher requirements for the Energy Star label substantially raising the bar for thermal and moisture building performance, however, that scenario may be changing. Easley makes a case for using closed-cell spray foam (ccSPF) to correct insulation woes as he highlights some of the most frequent problem areas addressed by the EPA’s Thermal Bypass Checklist Guide. (Costal Contractor)
Read more …
