A water-saving bathtub sounds counterintuitive, but the Sozo Bath’s design helps it make sense. Tapered inside walls reduce the amount of water consumed while comfortably supporting the bather in a reclined position, allowing for a lower overall depth. The tub measures fully 96 inches long, 30 inches wide, and 22 inches deep. Average water use for the bath would be 60 gallons for most bathers, compared with 75 gallons for other luxury baths. In keeping with an environmentally friendly message, all Diamond Spas are fabricated from recycled sheet metal, and are 100% recyclable. Diamond Spas | 800.951.7727 | diamondspas.com
Waterproof Gypsum Backerboard
Expansive Glass Wall
Interior Fire-Rated Plywood
