Toolbox: Metal Cutting Goes Cordless
10 MIN READ
Toolbox, continued
Tools that Measure Up
Time-Saving Siding Gauge.
Malco’s Panel Gauges not only give your siding the correct 1 1/4-inch overlap without measuring, they temporarily support both ends of the siding panel for easier installation, even when you’re working solo. The stainless-steel gauges are made for 5/16-inch-thick siding and will support the entire weight of a 12-foot panel. According to the manufacturer, the gauges require no adjustments and will last a lifetime.
Malco Products, 800/328-3530, www.malcotools.com.
Even Spacing for Your Casing.
Made specifically to speed the installation of door and window casing, the Trim-Loc practically guarantees consistent reveals, and it’s small enough to fit inside your toolbelt. Tape-measure slots hold your tape at a proper 3/16-inch reveal for accurate one-step measurements, and 45-degree guides assure tight miters at corners. But the coolest feature is that the tool allows the use of short-side measurements without a second pair of hands.
Bench Dog Inc., 800/786-8902, www.benchdog.com.
McGyver’s Layout Tool.
The manufacturer calls it the Swiss Army Knife of layout tools. It has almost as many functions but, sadly, no bottle opener. The Precision T is a 48-inch, aluminum straightedge with fold-out tabs for laying out plates. The 1 1/2-inch-wide tabs give the correct layout for both 16- and 24-inch on-center spacing. When the 24-inch removable leg is secured to the straightedge, the tool can be converted into a 4-foot, L-shaped framing square or a T-shaped drywall square. The removable leg can even transfer anchor bolt locations to mud sills. Finally, a removable vial insert changes the straightedge into a 4-foot spirit level.
Frame E-Z, 505/536-9411, www.frameez.com.
Magnetic Personality.
Klein’s new magnetic-tipped tape measures have a rare-earth magnet on the tip for easier solo measurements. The new tapes range in length from 16 to 30 feet and have a sturdy rubber-covered housing for increased grip and impact resistance. The tapes also feature a high-visibility orange case and multiriveted end hooks. Although most of us frame in wood, it’s still a good idea.
Klein Tools, 800/553-4676, www.kleintools.com.
Labor-Saving Painting Tools
Scraping By.
Scraping paint is about as exciting as watching it dry, so anything that promises to make the tedious process go faster deserves some serious consideration. Warner’s Carbide 100X Paint Scrapers are a definite improvement over traditional hardened-steel blades, and the manufacturer claims that they stay sharp 100 times longer. Cushioned handles are threaded for extension poles and provide a secure and comfortable grip. The scrapers are available in 5/8-inch round, 1-inch triangle, and 2- and 2 1/2-inch straight profiles. Straight versions have a front-mounted knob for additional scraping pressure.
Warner, 877/927-6378, www.warnertool.com.
Peel-and-Stick Protection.
Masking door hinges can really slow the otherwise rapid progress of paint spraying. But Door Hinge Protectors from Paint and Peel cover radius-corner 3 1/2-inch butt hinges in a single step without masking tape. According to the maker, the precut vinyl covers protect both sides and remove easily when the job is done.
Paint and Peel, 877/416-7246, www.paintnpeel.com.
Get a Handle on Vandals.
Graffiti is a problem for many homeowners and builders in urban areas. Anything stationary for more than a minute is a potential easel for an urban artiste. Dumond Chemicals, the makers of Peel Away stripper, recently introduced two new products for removing graffiti from buildings and equipment. The appropriately named Graffiti Remover is a citrus-based solvent that removes stains and most types of graffiti from masonry, glass, concrete, terrazzo, and metal. The product usually works within 15 minutes, according to the manufacturer. Lift Away Graffiti Towels remove graffiti from almost any hard, smooth surface with a convenient, slightly abrasive, premoistened cloth.
Dumond Chemicals, 212/869-6350, www.dumondchemicals.com.
A Quick Shave.
Promising to strip siding at the rate of 4 square feet per minute, the Paint Shaver uses a three-wing carbide cutter to quickly remove paint from flat surfaces. An acrylic shield with a profile-conforming base controls airborne particles and connects to your shop vacuum with a 1 1/4-inch port. According to the manufacturer, the tool removes paint at twice the rate of conventional sanders, and the carbide cutters will last for 5,000 square feet before needing replacement.
American International Tool, 800/932-5872, www.aittool.com.
Wet-Paint Blues.
If your nearsighted painter or helper is leaving the ceiling of your projects a little blotchy, you might suggest Ace’s Simply Magic Ceiling Paint. The flat white ceiling paint includes a blue colorant that’s added to the can just before application. The colorant practically guarantees proper coverage, and, magically, the paint turns white again in about 24 hours. Just be sure to tell your customers about the product first or expect a call from a frantic homeowner around suppertime.
Ace Paint, 708/720-0600, www.acehardware.com.
Time-Saving Saw Blades
Rip It Up.
Promising straight, smooth rips without jointing or sanding, Freud recently introduced the Glue Line Ripping Blade. The carbide-tipped, 30-tooth blade comes in Teflon-coated (LM74R) and polished (LM74M) versions. The 10-inch blades have a 12-degree hook angle and a triple-chip tooth design. The maker claims that a thicker kerf and laser-cut expansion slots eliminate vibration and deflection, producing cuts that can go right to the assembly table without additional prep.
Freud, 800/334-4107, www.freudtools.com.
Pull Out the Grout.
Regrouting or replacing a tile can go a lot smoother and faster with a Grout Grabber grout removal tool. According to the manufacturer, the offset, carbide-abrasive blade fits most common reciprocating saws. The 1/16-inch-thick blades can be stacked on the holder to accommodate grout lines up to 1/2 inch thick.
Grout Grabber, 888/447-2248, www.groutgrabber.com.
Terra Cutter.
If you’ve ever had to cut terra cotta (clay) waste pipe as part of a remodeling project, you know the brittle material is hard to get through without damaging it. Probably the best way for non-plumbers to cut the material is with an abrasive reciprocating saw blade like Lenox’s Master-Grit 600RG (plumbers use a special $300 tool called a snapper). These blades use a tungsten carbide abrasive bonded to the blade shank instead of teeth. The manufacturer claims that the blades also work well on fiberglass, cast iron, tile, marble, stone, and brick.
American Saw & Mfg., 877/886-2876, www.lenoxsaw.com.
Metal-Cutting Converter.
Many carbide-tipped metal-cutting blades are meant only for slower-turning cutoff saws, but Tenryu’s Steel-Pro PRF-18548DS Ferrous Metal-Cutting Blade is made for faster-spinning 7 1/4-inch circular saws. The PRF-18548DS blade’s 48 teeth have almost no rake and can safely spin up to 5,800 rpm. Although the blade does get some metal particles flying, it’s no worse than an abrasive blade. The PRF-18548DS can cut ferrous metals up to 1/4 inch thick, and it makes a clean cut without burning.
Tenryu America, Inc., 800/951-7297, www.tenryu.com.
