The Pella Steady Set system for new construction employs factory-attached components to help speed and improve window installation and enable more of the process to occur from inside a house. For instance, a “head stabilizer” engages with the rough opening to keep the window from falling inward; installation brackets just need to be unclipped, flipped, and clicked before being fastened to the framing; shim guides on the jambs hold shims in place; sill shims raise the unit 1/4 inch off the rough opening; and an exterior fin with continuous corners pops out ready for flashing tape after the window is set. Steady Set will be available on Pella Reserve and Lifestyle Series wood windows nationwide starting in the summer. pella.com
