In the summer of 2001, I took a one-week intensive timber-framing class at the Heartwood School, in Becket, Mass. There, my classmates and I learned how to lay out timbers and cut joinery. By the end of the week, we raised a small timber-framed pavilion and held a “topping out” ceremony where we placed an evergreen bough (more commonly known as a “wetting bush”) atop the pavilion’s ridge. Our instructors noted this tradition was to give thanks for a safe structure raising and to thank the forest for providing the timber. Now, some 17 years later into my timber-frame restoration career, my crew and I make it a point to celebrate a job well done with a topping out ceremony whenever we finish a frame (typically, one we’ve dismantled, restored, and then put back together).
The author tops out a restored barn’s frame with an evergreen bough or “wetting bush” in northern Vermont (above left). Here (above right), a wetting bush was placed on the ridge of a restored timber frame (the frame was dismantled, repaired, and moved to a new location by the author’s crew). The restored frame was used a main structure for a new home.
Photo by: Eliot Lothrop The author tops out a restored barn’s frame with an evergreen bough or “wetting bush” in northern Vermont (above left). Here (above right), a wetting bush was placed on the ridge of a restored timber frame (the frame was dismantled, repaired, and moved to a new location by the author’s crew). The restored frame was used a main structure for a new home.
Timber Frames
Clients often wonder why we go to the trouble of tacking a branch to the top of their frame. As with most traditions that span hundreds of years, the custom’s true origins are murky, but what is generally agreed on is that the placement of a wetting bush dates back to 8th-century Scandinavia.
Prior to the adoption of Christianity, trees were commonly worshipped as deities by early Europeans. In Scandinavian mythology, each tree had a spirit of its own; people originated from trees, and returned to trees after death. So, before constructing a home, the builders would formally ask permission from the forest to allow them to harvest a tree for building material. When the home was finished, the tree’s highest branch was placed on the highest peak of a newly completed frame in a gesture of appreciation from those who built the home, while also assuring the tree spirit still had a place to live. Over time, these individual tree spirits came to be represented by a single forest god. Evergreen boughs were no longer placed atop a home’s ridge to appease many spirits, but rather to elicit the blessings of the forest god.
A wetting bush tops out a recently built post-and-beam barn frame in New Hampshire.
Photo by: Brad Bull A wetting bush tops out a recently built post-and-beam barn frame in New Hampshire.
Wetting bush. The origin of the phrase “wetting bush” (sometimes referred to as “whetting bush”) is more apocryphal than “topping out.” The phrase is likely derived from the German tradition of “watering a bush” as a rite of passage for the home’s first nourishment. The placement of a pine bough symbolized the establishment of the home’s roots, which would then nourish and promote a long and prosperous life in the home. I’ve also been told that pinning the wetting bush to the building meant that it was time for the hearty drinking to begin.
Steel Frames
As steel began to replace timber as a structural material in the late 19th century, it would be ironworkers who would largely preserve the tradition of topping out the frame (“topping out” having fallen out of favor with most carpenters by the early 1900s). Today, the ceremony is an important custom in steel-frame construction, signaling that a structure’s “skeleton” has reached its topmost height. An evergreen tree (sometimes referred to as a Christmas tree) and a flag (typically an American flag) are attached to the final beam prior to hoisting it into place. This last, uppermost steel member is painted white and signed by the steel-erecting crews and visiting dignitaries. A topping out party usually follows, when the ironworkers are treated to food and drink.
In steel-frame construction, the “topping out” ceremony has evolved to include four elements: an evergreen tree, a celebratory party, the flag, and the signing of the beam.
Photo by: Holloman Air Force Base; N.M. Senior Airman Leah Ferrante In steel-frame construction, the “topping out” ceremony has evolved to include four elements: an evergreen tree, a celebratory party, the flag, and the signing of the beam.
Evergreen tree. There is no consensus among modern ironworkers on when and how evergreen trees came to be used, or even what they represent in the topping out ceremony. For some, the evergreen symbolizes that the frame was erected safely with no accidents to personnel, while for others it’s a good luck talisman for the future occupants. Of note, early photo engravings of ironworkers typically do not show any evidence of topping out ceremonies. This may be due to high fatality rates in early steel-frame construction, where such symbolism may have been deemed to be inappropriate.
The flag. The inclusion of an American flag in the ceremony is easier to trace. During the early part of the 20th century, labor unions were seen in some quarters as un-American (ironworkers were largely unionized, much like they are today). Including an American flag became a way for ironworkers to demonstrate that their unionism was not inconsistent with their patriotism.
