| Bridgewood | Table Size | Motor | Spindle Size | Reversible | Weight | Drive |
| BW-310SL | 29 x 23 inches | 3-hp | 1/2-, 3/4-, 1-1/4-inches | Yes | 471 pounds | Belt drive |
StoryID
501342
ToolNumber
1
ComponentId
tcm:78-1626861
Tester Comments This is a solid tool. Access to everything is easy and from the front. There s a nice range of travel on the fence and spindle and the hold-down system is my favorite. The spindle locks down hard and with nearly zero play. It has a 4-inch dust port and an optional sliding table. They test each tool at the factory before shipping, and it shows. Plus, I just love the red toolbox. | Price 1,295 Contact Bridgewood 800-235-2100 www.bridgewood.com | null | null | null | null |
| Delta | Table Size | Motor | Spindle Size | Reversible | Weight | Drive |
| 43-495X | 40 x 27 inches | 3-hp | 3/4-inch | Yes | 436 pounds | Belt drive |
StoryID
501342
ToolNumber
2
ComponentId
tcm:78-1626861
Tester Comments This is my favorite. Access to everything is from the front. Changing speeds, spindles, and cutters is a breeze. The huge table with two fence placement options is a real plus. The fence has the broadest range of adjustment and is the easiest to use. The spindle locked down solidly with zero play. It runs smoothly and is set up for dust collection. | Price 1,699 Contact Delta Machinery 800-438-2486 www.deltamachinery.com | null | null | null | null |
| Grizzly | Table Size | Motor | Spindle Size | Reversible | Weight | Drive |
| G1026 | 30-1/2 x 38-1/4 inches | 3-hp | 1/2-, 3/4-, 1-inch | Yes | 345 pounds | Belt drive |
StoryID
501342
ToolNumber
3
ComponentId
tcm:78-1626861
Tester Comments This machine works well but lacks some refinements. The table is large enough, but the fence is small with a limited adjustment range. The hold-downs are fine. The switches are in front and easy-to-reach. Rear-access for changing speeds and spindles is inconvenient. The spindle lock-down has some play. Dust collection is optional. However, it delivered hard-working, reliable performance. | Price 825 Contact Grizzly Industrial 800-523-4777 www.grizzly.com | null | null | null | null |
| JET | Table Size | Motor | Spindle Size | Reversible | Weight | Drive |
| JWS-25CS | 25 x 25 inches | 3-hp | 1/2-, 3/4-inch | Yes | 320 pounds | Belt drive |
StoryID
501342
ToolNumber
4
ComponentId
tcm:78-1626861
Tester Comments The Jet is well-finished and smooth-running. It comes nicely equipped with two collets and two spindles. The fence is small and limited, but the tool has a dust port and a nice cutter guard. Hold-downs are fair. Changing cutters is pretty easy. It has the most play in the spindle. Access for belt and spindle changes is from the back of the machine. On/off switches are in front and easy-to-reach. It’s a basic tool that works hard and well. | Price 1,250 Contact WMH Tool Group 800-274-6848 www.wmhtoolgroup.com | null | null | null | null |
| Rojek | Table Size | Motor | Spindle Size | Reversible | Weight | Drive |
| FSN 300F | 39-3/8 x 18-1/2 inches | 3.6-hp | 3/4 x 1-1/4-inch step spindle | Yes | 375 pounds | Belt drive |
StoryID
501342
ToolNumber
5
ComponentId
tcm:78-1626861
Tester Comments Rojek’s finish is wonderful. The fence/hold-down system is accurate, easy-to-use, and reliable. The spindle locks solidly in place with zero play. The table is long, but narrow. Rojek offers a sliding table option. Front-access makes changing between the five speeds easy. The motor is the largest and the soft-start feature is nice. | Price 1,975 Contact Rojek Woodworking Machinery 800-787-6747 www.rojekusa.com | null | null | null | null |
